Mello_Mike
Dec 22, 2015Explorer
BFL13 wrote:
When you park the TC, do you unplug the truck to camper 7 (or 6) pin?
I do to keep the truck's battery from running down (Chev truck, no isolation)
That leaves the TC 7-pin socket empty, So you could add a 7-pin type plug to the battery wires on the suitcase (pin 4 and ground only) and just plug the suitcase (which has the built-in controller) into that, which will then charge the TC battery in parallel with the other solar set.
Not ideal for distance from controller to battery, but you still get something from it.
No, it's always plugged in. I have a battery isolater in my truck camper. Your idea has merit except I always leave my camper plugged in. It might work for someone else, though.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
