NinerBikes
Dec 22, 2015Explorer
Mixing different watts and different input voltages from different panels will confuse the MPPT. If you use a PWM charge controller and run all parallel inputs into a 20 amp PWM controller, you will get better results.
You will be lucky to get 5.5 amps out of a 100 watt suitcase solar panel. Don't ask me how I know this. I was lucky to get 6.2 to 6.3 amps out of my 120W solar panel in early October, aiming at the sun. Less in winter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
