Almot
Dec 22, 2015Explorer III
If you have space left on the roof, you can add one more panel - as big as you can. 140W flat will work the same as 100W tilted. BFL will probably argue with graphs and numbers, that is is not quite "the same" during fall and spring seasons when sun is low, - but it won't be much different either. Last time I checked, AZ was pretty far South.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
