kjenckes's avatar
kjenckes
Solar and battery help
Good Morning. I am hoping someone can provide a simple answer or 4 for me. I just read a post on the TC forum about flexible, light weight 100 watt solar panels and love the look of this, I have a Northstar 850SC pop up that this would go on. I have plenty of room over the bed end for these with out shadows from roof top stuff. I currently have 1 Interstate SRM-27 listed as 160 RC. (I will be adding a 2nd) I would prefer 31s but am not sure about the space available yet.
#1- Does the 160 RC on the battery mean 160 amps?
#2-50% discharge or 80amps (If #1 is yes) or 12.2 volts is the lowest I want to take this battery on a regular basis, correct? Therefore 2 would give me 160 amps?
#3- The listed optimum amps for this 100W panel is 5.7 amps with a max fuse of 10amps. Does this mean that 2 of these on the 20 amp controller is appropriate as the minimum? 30 safer? Could I run 3 on a 30?
#4- What is the rule of thumb for minimums watts per battery? I know sunlight hours and shade, etc affect all of this. I see some with 270 or more watts but no mention of how many batteries this supports.
My goal with all this is to get my wife out more with me. We both use CPAP (12v ). She is not as comfy with out some of the comforts of home as I am. We live in NH and the State Parks in NH and VT as well as the White Mt. and Green Mt. National Forest sites are almost entirely off grid.
I have learned a lot from this forum and want to thank every one for their posts.
  • Thank you everyone for all of your time and help. With 238 views to this point I imagine it has helped many others as well.
  • RC is reserve capacity in minutes. 160 RC = 25 amps for 160 minutes before you reach 10.5 volts. It is a hybrid rating as it does measure a deep cycle but at a fairly heavy load. More capacity available with a slower discharge.
  • Almot's avatar
    Almot
    Explorer III
    She won't be too happy on solar. Not with 2*100W for sure. "Some" comforts of home can draw more than 70% of your daily solar harvest, and nearly all of those comforts you can either live without or find low-energy substitutes. But when lady wants something, there is no use in reasoning. My friend living fulltime in 5-er with 400W solar has to run a generator every time when DW sits down with her favorite pastime - quilted blankets, it needs big 120V iron.
    #3: With nominal 12V panels, i.e. up to 160W each, the controller amps rating = total panel amps + 20%. So with 4*5.7A you need roughly 30A controller. With larger panels like 200W each, controller rating is calculated differently.
    I don't know why you've set your mind on flexible 100W - bigger wattage rigid panels are cheaper per watt. Also, more durable. Like Roy said, try getting as much solar up on the roof as you can. It should be possible to put more than 400W on a TC.
    #4: The rule of N watts per M amp-hours of battery (roughly 1W per 1 AH) is a minimum wattage, to make sure that battery will get fully charged on a good day. There is no such thing as too much solar, the more - the better. On a dark day a 500W solar will collect as little as a 100W solar on a good day.
    And, as soon as you batteries will start showing signs of aging (shouldn't take long) - replace them with proper deep-cycle ones. This is NOT an option.
    No RC is reserve cranking amps; 160 RC implies 95 to 105 aH
    12.2 volts is a good choice; two size 27 deep cycles will be 190 aH to 210aH
    Depends on the controller size; fuse sizing is determined by NEC
    The rule of thumb is 80 to 100 watts per 100 aH of battery
    The output of a solar panel will vary quite a bit over time of year and full sun vs cloudy or shade. Max output usually occurs between 10 AM and 3 PM in full sun but this is another general rule. We have two 80 watt panels feeding a TS-45 controller which charges a pair of Exide Stowaway 105 aH batteries. All main lighting is LED, no microwave, TV, or other high usage (wattage) devices. We are very conservative with power usage and get 7 to 10 days before the batteries reach 12.2 volts(60% soc). Connecting the solar panels at that point takes 4 to 6 hours to recover the 40% used.
    I suggest an internet search for the 12 volt side of life and a visit to batteryfaq.org.
    Wiring between the panels should be as short as possible and no smaller the 10 awg. Batteries should be the same age and wiring from the controller to the batteries no smaller then 8 awg.
    If you decide on 3 panels you may find the cost of a mppt controller to be worth while(300 watts is right at the dividing line).
    For cpap you want the most efficient your budget can afford if going with 12 volt.
  • Quote:
    Readers, beware !!
  • Almot's avatar
    Almot
    Explorer III
    You're lucky somebody like BFL13 haven't read this, or you would've been labeled as a caveman :)... Every time I'm telling that one CAN live on 30-35 AH a day and have hot meals, warm trailer and some laptop or TV time, a lot of people get skeptical. Living without a microwave is considered impossible, for some reason.
    8 days down to 60% on a pair of 105AH batts means 84 Ah total or 11 AH a day. I would say, this is too low even by my standards. Propane fridge draws at least 8 AH a day. AGM battery self-discharge is negligible, alright, but remaining 3 AH (or less) leaves you with a couple of LED lights and not much more. No fan in a hot weather, no heater (other than non-vented propane).
    It would be difficult harvesting 84 AH in one day with 160W solar. With flat permanently mounted panels - very difficult. With portable panels - still difficult, but maybe, yes. Tilting and changing the azimuth angle every hour, and on the longest day of summer and if it's really sunny and not too hot. The bottom line - I wouldn't count on getting that much. Unless you are somewhere close to equator.
  • His real crime is taking a week to get down to 50% all the while his batteries are undercharged and sulfating like mad. Too long between recharges.
    Another crimes is using a TS45 when a $15 RJ Special controller would do. :)
    As for 84AH with 160w, I was getting 56AH flat, 70AH tilted, and 90 AH tracking with my 130w in May at 49.3N
  • Almot's avatar
    Almot
    Explorer III
    Must be one of those occasions when I (almost) agree with BFL.
    Yes, TS45 is overkill unless there are plans to expand to at least 500W. Some 10A-15A Morningstar or Steka would do - or Xantrex PWM 35, they all cost about the same. I would not buy $15 gizmo when solar is the only source of power and therefore needs to be reliable.
    I'm not sure about sulfating in AGM. What he is doing is a one week-long cycle 100 to 60, and only then charging it to 100 again. Kinda self-discharge, only faster. You can let AGM sit and self-discharge all year, it will drop to about 60% over that period without major consequences.
    Though I would rather keep them charging every day, getting 11 AH a day shouldn't be difficult unless the weather pattern is 7 days of rain and then all sunny. In fact, with daily charging they would need less than 11 because some juice would've got directly to devices in daytime, so the battery would discharge by less than 11 AH a day.
