ajriding
Jan 23, 2020Explorer II
Solar and Charger into one?
I am modifying my cargo trailer to be more like a camper, and dug up some old stuff for it.
I have a modern MPPT solar controller for the 100 watt (soon to be 200w).
Two golf cart batteries.
I have an old 12.7 volt, 15 amp DC power source of a 1972 Winnabago, attached to a 115 circuit breaker box complete with shoreline/generator switch.
I am sure there is no monitor on the DC charger/power source.
The solar I know how to set up no problem, no questions.
The power source no problems either.
What I want to do is have the shoreline DC power source be "smart". I do not want to just send 15 amps to the battery everytime I plug in or want to use the DC power source instead of the batteries. I will be running a Danfoss chest fridge, and just minimal lights and minimal charging, min fan etc.
I do not want to buy a $500 controller that controls both power sources (solar and charger) electronically, but can spend under $50 for something to make it all work together.
The breaker box does have a breaker for the charger if it comes to that so I can still plug in and have shore power for AC or electric heat without charging (overcharging) the battery.
I would rather have something monitor the battery automatically, so looking for a thing maybe to go between charger and the battery to control the charge while the solar works in the daytime but not at night.
Keeping the battery in float while running the fridge and outlets off the charger/converter is the most preferred solution.
Anyone tackled this?
