twodownzero
Jan 09, 2020Explorer
You will need to disable the converter when the inverter is making 120 volts. Otherwise you're just going to be turning the contents of your battery/solar into heat with an endless loop, as nothing is 100% efficient.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
