Osiris
Jan 09, 2020Explorer
BFL13 wrote:
You just need to choose a solar controller with adjustable voltage so you can match voltages with your charger so they add their amps.
No harm in having both on at once even if their voltages don't match; it would only affect how many amps you get.
Please use "converter" or "inverter/charger" instead of "inverter", which is a different device, to avoid confusion.
So to clarify, if both are connected at once without the solar controller, would that lower the amps provided by the converter and result in slower charging? Just trying to understand what the result of the amps changing would be.
Also, is there a reasonably priced solar controller you can recommend? My panel is not large, it is meant to trickle charge.
thanks again!!
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
