2oldman
Jan 09, 2020Explorer II
twodownzero wrote:I'm pretty sure his inverter is an inverter/charger.
You will need to disable the converter when the inverter is making 120 volts.
Two charging sources at once is usually not a problem. They either work together or one just cuts out.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
