Osiris
Jan 09, 2020Explorer
2oldman wrote:
I'm pretty sure his inverter is an inverter/charger.
Two charging sources at once is usually not a problem. They either work together or one just cuts out.
Correct, it is an inverter/charger. Well, if i'm running the generator, i wouldn't want the inverter/charger to cut out, i'd rather have the solar panel cut out if anything. How can i determine if this will happen?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
