BFL13
Jan 09, 2020Explorer II
Even a trickle solar charger should have a controller so it can keep the voltage from going too high for the batteries.
The batteries will charge from the source with the higher voltage. If the converter is at 13.6v and the solar is at 14.6v, you will get the amps from the solar.
To get your full amps from the converter while the gen is running to recharge low batteries, you want the solar's voltage to be close to the converter's voltage, following the same voltage "profile" (stages)as the battery charges up. They will then add their amps all the way.
The converter will also trickle charge a full battery. No need for the solar trickle charger to be "on" when the converter is on the full battery, but if it is, it doesn't matter which has the higher voltage.
What is the scenario? No shore power, just generator every so often while off-grid? Or storage not camping and off-grid? If off-grid and camping then the trickle charging solar is nearly useless, so IMO go for a serious solar set-up. Trickle would be good for off-grid storage. If on-grid, no need for solar at all.
Can't recommend anything without knowing the scenario.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
