2oldman
Jan 09, 2020Explorer II
Osiris wrote:First you need to set all this up and see what actually happens.
Well, if i'm running the generator, i wouldn't want the inverter/charger to cut out, i'd rather have the solar panel cut out if anything. How can i determine if this will happen?
You may be able to set the controller's bulk charging voltage to a lower number than the IC. Also, many of us put disconnect switches between the panels and the controller.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
