pianotuna
Jan 09, 2020Nomad III
Yes, multiple charging sources work.
I can use the OEM converter, hybrid inverter/charger, solar, and alternator, all at the same time. The converter and the inverter/charger would be powered via shore power or generator.
In real life, I leave the converter disconnected from the 120 volt source.
I do have a bi directional amp meter between the alternator and the house batteries. It often shows power flowing from the house to the engine.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
