MrWizard
Jan 10, 2020Moderator
Osiris wrote:MrWizard wrote:
To the OP
You said inverter
Do you mean converter for charging the batteries
Or possibly
Inverter charger Combo, charges battery when generator is on,
Makes 120v when the generator is off
yes, inverter/charger combo. It doesn't do anything when generator is off.
Are you sure?
An inverter combo Will make 120v from your battery when the generator is off, Unless that function is turned off
Sounds like you have a standard converter aka charge only
Just hook all your 12vDC together
Battery, converter, and your new solar (no problems all is good)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
