BFL13
Jul 26, 2015Explorer II
phemens wrote:
I have 3 12v panels (2x 80w, 1 x 135w) feeding into a Rogue 3024 MPPT controller, which then feeds 4 x T125 Trojans. I want to add another panel, was wondering if there is any way to add a 24v panel as a 2nd array to the 3024, or do I have to add another 12v to the existing array?
the two 80s in parallel for 12v 160 and that in series with the 12v 135 makes a 24v, then parallel that 24 with the new single 24. However I do not know the controller's Voc or amps limits
Also you might run out of wire! :)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
