Golden_HVAC
Mar 17, 2015Explorer
It seems to me that using Li-Ion battery or lead acid battery or NiMh batteries will work out great with normal $1 per rated watt solar panels and a PWM controller would work great!
I can order a 20 amp 12 volt PWM controller for $13.
I can order a 100 watt solar panel for about $100 - $150 from this website. SunElec.com
I can make solar panel mounts from 6" long 2" angle aluminum from Home Depot for less than $2 each. 3 each 3/16" holes for #10 screws into the roof and 5/16" hole for a 1/4" bolt into the panel framework will finish the mount. Some rubber roof sealant and you are done.
You have to take care, and only buy a panel that will fit on your roof, without getting to close to the shadows, such as the A/C or antenna. And leave space to walk around the roof for maintenance.
#10 UV rated direct burial romex is grey and sold at Home Depot. You can use that to go behind the refrigerator to the controller, then on to the battery with more flexible #8 building wire.
Then you can install a 400 watt system for less than $600, and have plenty of power for a RV. While not camping, it is practical to run some of your home lights on the RV system (if parked near the home) via a 12 volt distribution system, or with a inverter and run a 110 volt power cord to run items like the TV set or other things that will consume less power than the solar system makes on a daily basis.
The RV battery will act as the storage system. It is very effective, and I would cycle through about 120 amp hours with my 400 watt solar system while camping, and completely recharge the next day.
Right now, for homes, the most energy efficient system is to use a batteryless inverter, and sell back power to the local supplier. This helps the supplier, as their most expensive power is that generated between noon and 5 pm, when most solar systems are working at their peak wattage. A batteryless system can convert up to about 95% of the sunlight wattage leaving the panels into energy that is sold to the power company.
Battery systems can lose 10% of the power capacity of the battery each month! So installing a 440 amp hour battery, you would lose 44 AH monthly, or at 13 volts about 700 watts a month! That can add up over time. Also the battery based inverters are not 96% efficient, more likely 85% to 90% on the best units, and much less efficient on the cheaper inverters.
Good luck!
Fred.
Good luck!
Fred.
