scrubjaysnest
Feb 02, 2016Explorer
sfpcservice wrote:
It is actually a WFCO 8845. I can get it to go into boost because I built a charge wizard type of remote. My controller has a remote plug and it was pretty easy to figure out what the 3 pins did. If a solar controller won't work my next thought was a dc-dc step up controller. I could set the voltage where I want and the amperage at max, and I assume it would pump full current in and taper of as the voltage I set was achieved...?
Also the main problem is mine will only hit 14.25v and timeout after 4 hours... this is where a hydrometer shows I am just above dead...
Use this for a boat anchor and get either a progressive dynamics or iota. The WFCO's are junk. The 8955 I had would never go into boost/bulk mode; only absorb and float. Many others here have the same complaint.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
