BFL13
Nov 12, 2020Explorer II
Hondacanoe wrote:
Yes 100 watt. When plugged in the outlets didn’t work.
Thanks for the answer. Makes sense. Easy test. I’ll post results when finished.
Are the reverse polarity fuses on the controller or the converter?
Thanks
Ok that is new important info! The outlets and the converter are 120v things you power from shore power, generator, or inverter (not supposed to run the converter off the inverter though).
Your converter can't work if you have no 120v as indicated by the outlets not working either.
This has absolutely nothing to do with the solar. So need to start over and get your 120v working. Look for a GFCI popped (rain or washing hose in outside receptacle? ("outlet" in newspeak)? Snap the main 30a breaker in RV back and forth. If on shore power from the house, check the breaker for that house receptacle in the house's breaker panel.
The RP fuses are on the deck mount converter itself or with a hardwired Parallax 7xxx they can be on the DC fuse panel close by the converter --all in the power centre with the converter being the "lower portion"
