Almot
Nov 13, 2020Explorer III
Hondacanoe wrote:
Is there a way to test polarity from solar panel?
Take multimeter, set it to 100V DC, hold panel to the sun, connect probes to the panel - without battery or controller.
If it reads ~18V, then red probe is on the Pos wire of the panel. If it reads negative voltage, then red probe is on the negative wire of the panel. That is, if you plugged red/black leads into voltmeter correctly. Some voltmeters have leads permanently attached.
As noted, never connect controller to panel when controller is not connected to battery.
