BFL13
Aug 27, 2014Explorer II
wbwood wrote:
So the 190 and 200 watt panels mentioned are per panel or all together?
If I purchase a couple of 100 watt panels (not permanently mounting them), then a pwm will suffice?
Expected amps from a 100w panel is about 6.3a aimed at a high sun, so total for two is 12.6a. You need a 20% margin above that in controller amps rating to allow for when the panel exceeds its ratings. So another 2.6a is 15.2a.
You could go with a 15a controller or a 20a for nearly the same price. Any old eBay 15 or 20a controller will do the job for under $15. BTW don't get sucked in by claims of MPPT on those, they are actually PWM. Cheapest MPPT is about $100 by comparison (Eco-Worthy 20amper)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
