BFL13
Aug 28, 2014Explorer II
steveh27 wrote:
I seem to have a problem with my 120 watt portable:
http://www.amazon.com/Infomon-Monocrystallline-Portable-Folding-Solar/dp/B005WMD8VY/ref=cm_cr-mr-title
I've had it 2 years & only used it a few times. I was getting up to the 6 amps it puts out, but now I'm only getting up to 3 amps.
It has this cheap controller:
http://www.ebay.com/itm/Solar-Charge-Controller-Overloading-Short-circuit-Reverse-Discharging-Protection-/300916227986?tfrom=301218792237&tpos=top&ttype=coupon&talgo=undefined
This year I did install a quick disconnect plug to the battery through the box for easy plug in. That 1 foot short wire is 18 ga.
The 2 wires I used before came with the panel are 18 gauge. 1 is 15 foot long with clamps for the hookup. The other is a 25' extension with the quick disconnect plugs. I just put together a 10 gauge wire 22' foot long with the quick disconnects. All 3 wire hookups give me only up to 3 amps, even the clamps direct to the battery. Yesterday I checked the panels Open Current Voltage & it was over 20 volts even through the 25' extension. It's rated at 21.8 I could not get my multimeter to work checking the Short Circuit Current amps. (I'm a novice with it). It's rated at 7.3. I did clean the panel, no change.
Today I hope to check the SCC amps with the multimeter, and cover one of the panel sides to see if either is not connected properly. Any other ideas?
You should get all 7.3a at the battery with panel aimed at high sun. First get the Isc with the meter with panel not connected to battery. Then connect to battery. If you get less than whatever Isc is at the time (it varies with amount of insolation) at the battery, find your wiring problem. (18 gauge is very skinny---I used #8 with my 130w panel.
Your 20.x voltage is ok. The panel gets hot and loses voltage so 20.3 w would be typical for a panel rated 21.9 eg. Luckily amps go up with heat so PWM does not lose any amps. (unlike MPPT in heat)
