NinerBikes
Aug 28, 2014Explorer
steveh27 wrote:
I seem to have a problem with my 120 watt portable:
http://www.amazon.com/Infomon-Monocrystallline-Portable-Folding-Solar/dp/B005WMD8VY/ref=cm_cr-mr-title
I've had it 2 years & only used it a few times. I was getting up to the 6 amps it puts out, but now I'm only getting up to 3 amps.
It has this cheap controller:
http://www.ebay.com/itm/Solar-Charge-Controller-Overloading-Short-circuit-Reverse-Discharging-Protection-/300916227986?tfrom=301218792237&tpos=top&ttype=coupon&talgo=undefined
This year I did install a quick disconnect plug to the battery through the box for easy plug in. That 1 foot short wire is 18 ga.
The 2 wires I used before came with the panel are 18 gauge. 1 is 15 foot long with clamps for the hookup. The other is a 25' extension with the quick disconnect plugs. I just put together a 10 gauge wire 22' foot long with the quick disconnects. All 3 wire hookups give me only up to 3 amps, even the clamps direct to the battery. Yesterday I checked the panels Open Current Voltage & it was over 20 volts even through the 25' extension. It's rated at 21.8 I could not get my multimeter to work checking the Short Circuit Current amps. (I'm a novice with it). It's rated at 7.3. I did clean the panel, no change.
Today I hope to check the SCC amps with the multimeter, and cover one of the panel sides to see if either is not connected properly. Any other ideas?
Sounds to me like you are only getting output from one panel out of the two folding panels. Time to check all the electrical connections, starting with removing the covers off the black boxes of each panel, before the charge controller. Get a DC amp clamp, and clamp it over each red wire while solar panel is directed at the sun, while trying to charge your battery when it needs a deep recharge and tell us what each panel flows for amps.
