steveh27
Aug 28, 2014Explorer
I discovered why my multimeter wouldn't show the Short Circuit Current (SCC). The 20 amp fuse was bad. I did check behind both panel's black boxes & the connections are good. One registered Open Current Voltage (OCV) of 21.2 the other 20.8. It's rated at 21.8. The rated SCC is 7.2 amps with max output of 6.67 amp.
Results:
SCC from controller connection = 6.5
from 25' 18 ga = 6.7
from 22' 10 ga = 6.6
I need to make the final solder & heat shrink connections on the 10 ga. wire. I may shorten it a bit to 16-18' if that needs done & would help.
Now my battery has a SOC of 87% with 12.7 v and a draw of -0.2a. When connected with the various cords my Trimetric shows:
with 25' 18 ga = 13.1 v and +2.9a
with 22' 10 ga = 13.2 v and +3.0a the v went up a bit the longer connected
with 16' 18 ga wire clamped direct to battery = 13.3v and 3.0a.
Maybe all is well & I just do not drain the battery enough to allow all the amps to charge?
Results:
