valhalla360
Nov 06, 2022Navigator
Do an energy audit.
- Each device will have a watt rating (possibly amps @ volt rating which can get you to watts.
- Estimate how long each device will run.
- Multiply watts * hours (amp * volt * hours alternatively) to get to watt-hr.
- This is your consumption per day.
- Assuming 50% of the battery bank is usable for lead-acid batteries, so multiply the amp-hr * 12v * 0.5 to get usable watt-hr.
So by dividing usable watt-hr by daily watt-hr consumption, you have an idea of how long the battery bank (by itself) will last.
- If it's 3 or more days, you can charge while in storage which means a much smaller solar array. Or it can be much more convenient to run the generator once per trip.
- If it's below 2 days, you are looking at replacing the consumed power daily.
Solar: A good rule of thumb is for every watt of solar panel rating, you will get around 4w-hr of daily output (assuming clear view of the sun). So a 100w panel should generate somewhere around 400w-hr per day.
- If your daily consumption is 600w-hr, you need around 150w of panels, though I would round up to 200w. That way, if there is less than ideal conditions or you missed a bit of consumption, you are still covered.
- If you do have 3 days worth of battery storage and will rarely have less than 3 days between trips, you can divide the amount you need to replace after a trip by 3 and then make the same calculation...ie: if you are down 1200w after a trip, you need to replace 400w-hr per day, so a 100w panel should have you topped up before the next trip.
This is much better than randomly picking a solar panel size because it worked for someone else.
