donn0128
Jun 03, 2013Explorer II
Not sure I follow your? Your panels I assume will be mounted on the roof? From there you run wire down to the charge controller and from the controller to the batteries. That's all you need to do. If you run the generator, it is like shore power it charges the batteries via the converter. Your solar charge controller takes care of everything else.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
