FlatBroke
Jun 03, 2013Explorer II
MrJoelieC wrote:
Thanks for the replies.. The LEDs are already on order.. I was planing on a portable 120 watt panel set to start... I'm leary of adding large expensive panels permanently to the top of the RV for Reasons:
1) Live in New Hampshire..
2) Because I live in New Hampshire I have many trees in my yard.
3) Because I live in New Hampshire with many trees - Ice tends to build up on said trees and cause limbs of said trees to fall onto things...
Thus I figured I would either buy a portable set or 2 and thus I would also have option to set camper in a space in shade and move panels into sun with judicious beer drinking and panel moving to track sun for maximum efficiency.. (Eerrrr-uhm Hopefully the beer-drinking wont hinder that process too much.)
I figured it would be fine But I thought I would just double check...
Thats what I do. If you set the panels direct to the sun they put out every amp they are suppose to. You will be surprised how even the slightest angle cuts the amps.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
