Golden_HVAC
Sep 13, 2013Explorer
Hi,
I would not suggest getting anything as small as a 15 watt solar panel. The cost has come down a lot on the larger solar panels, you can get a 100 - 150 watt panel for a little over $1 per rated watt. You can get a China 10 amp controller for about $15. Then you will have a "real" solar system, that will recharge your battery, not just keep it from going dead in a few days.
Your RV has some loads on it, such as the CO meter and propane detector that will consume 35 amp hours per day, or about what a 120 watt solar panel will put out in one day.
SolaronSale.com is one place, SunElec.com is another.
Good luck!
Fred.
Good luck!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
