time2roll
Sep 22, 2020Nomad
If you run parallel you can use a PWM controller that just clips the voltage. If you run series you need the better MPPT controller that converts all amps and volts to the proper voltage and maximum amps. This holds watts or total power constant.
There’s a lot to know.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
