CA_Traveler
Sep 22, 2020Explorer III
Boon Docker wrote:Panels contain constant voltage devices. 6A at 30V = 180W and 6V at 20V = 120W or 2/3 of that panel power.CA Traveler wrote:
See my 7:03am post today. The bypass diode acts like a direct short with 0V and conducting all amps. Well OK there is a small voltage drop (0.3V) across the diode. The other 2 panel sections are still producing 10V each with the amps.
So a panel that produces 6 amps at 30v (full sun) would produce with partial shading 6 amps at 20v. How is it possible that a panel operating at 2/3 can still produce 6 amps.
MPPT controllers convert power (watts) for the load, PWM controllers pass amps to the load.
Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
