ajriding
Sep 24, 2020Explorer II
honestly, In real life, I couldn't tell the difference in PWM parallel or MPPT series with two 100w panels. Both would get the batts charged during the day, and the biggie is using power overnight since the was plenty of available power from the panels during the day.
I would have added more panels, but ran out of roof space.
I like running the panels in series as I can use smaller wire, and use less wire (or if the same wire then at higher volts is a bit less loss).
I have a backup mppt on hand in a faraday cage, n hope the panels can survive the worst.
I am hopeful mass arrst are made Nov 4 and "within" enemies are taken out, but enemies from afar are always a threat.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
