obiwancanoli's avatar
obiwancanoli
Solar charging - can it be so?
I'm still trying to wrap my head around the solar and power issue, but I have learned a lot. In conversation with my RV service tech, an independent guy who takes pride in his knowledge and work, I was listening to him discuss the wiring issue, in conjunction with a new Victron controller (100/50) and Victron 712 Voltmeter he'll be installing this week.
Something my tech said about properly wiring the solar panels - in series, I think - got me to wondering...., rather than the alternative setup, pretty much has a good 5-hour window (10-3) for maximum charging, where in series would allow the panels to begin charging as soon as daylight hits, albeit at a lower rate, of course.
I've always heard that maximum performance of any solar panel was generally limited to the most direct sunlite one can have - about 5 hours. And clouds, trees, buildings, etc., severely reduce their capabilities, if not altogether eliminated them.
Now I'm thinking I heard my tech say that properly wired, panels would recharge batteries as soon as daylight appeared, and through the day until dusk, and I assume he said this knowing a new Voltmeter and MPPT 100/50 Controller (Victron's) would also be installed. He also stated he'd seen solar charge batteries sitting under a flourescent light!
Could it be true?!?!?!
  • Detail. Solar panels in series would charge longer during the day. That’s the good news. The bad news is that any part of any panel that is shaded will reduce the output of the whole array. When I bought my panels, I bought 12 volt panels, and because I have shading issues all the time here on the highly treed east coast, I’ve chosen to put half the panels in each of two series and then parallel the two halves. This to try and get the maximum output no matter what. The controller can handle up to 150 volts input from the array, no need to buy 12 volt panels, so if I were doing it again, I’d buy 24 volt panels, but I’d still do the paralleled pair of series panels.
    If I were in the part of the country where shady campsites were the exception, I’d go series all the way. And here’s the beauty of those MC4 connectors: if you pay attention to connector placement during installation, it is simple to switch between parallel and series to change configuration for the conditions at hand.
  • 3 tons wrote:
    Regardless of their source - the basics are that photons can excite electrons from the phosphorus doped side of a PV diode to jump the barrier gate to get to the boron doped side...e.g. my 440w panels begin to harvest at sunrise and 200a Li battery charging (beginning at about 60% SOC) is often complete before or shortly after noon time, this mostly due to the high receptivity rate of Li..
    3 tons
    Precisely why I opted for Lithium batteries, to be installed next week, following the installs of the MPPT and V-meter
  • 3_tons's avatar
    3_tons
    Explorer III
    3 tons
  • Panels start producing voltage at very early morning light, however the amps are low. Maximum power occurs at noonish and their is significant power for several hours on either side. The power produced looks like a bell curve.
    Other power factors include weather, panel orientation, time of day, time of year, shadows and temperature.
    As a ball park figure I use 67% of the panel watts for 4-5 hours.
  • bgum wrote:
    Issue: can an artificial light cause a solar panel to create a charge? Yes
    It's strange to recall this now, but back when I used to travel daily to this thing called an "office", I'd see something in the men's room that always cracked me up: The soap dispenser and the automatic water valve (turned on and off by a beam that detected your hands) were both solar powered. The lights in the bathroom fed the little panels in the soap dispenser and water fixture.
    It was one of those things that I had to force myself to not think too hard about, because I didn't want to blow a fuse.
  • Sure. Is it effective, no, but you get something off the panels. Good choice on the Victron MPPT and monitor. I would encourage you to get the version that has Bluetooth, their app is very handy for monitoring.
  • Issue: can an artificial light cause a solar panel to create a charge? Yes
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
