MDKMDK
Apr 19, 2020Explorer
DarkSkySeeker wrote:
Is the amperage from a solar panel constant as the battery it is charging charges up?
No. Solar panels aren't an exact science. Solar input affects panel output. Shade (clouds), sun to panel angles, TOD, charge controller charge algorithms, many things affect the amount of charging output that reaches the battery.
DarkSkySeeker wrote:If the charge controller sees and reacts to the increasing internal resistance of the battery to accepting more charge as it fills up, yes.
I.e., as your battery reaches full charge, the current drops to zero either via the charge controller or the equalization of the panel and battery, right?
DarkSkySeeker wrote:Yes, that math is false. Real numbers are probably closer to Mr. Wizard's numbers.
So this simple math is false? 120 watt panel, 12 volt system, 10 amps, 10 hours to charge a 100 Amp Hour battery?
You didn't ask about the differences between lithium and lead acid charging? That's where the opinions really start to diverge. :E
p.s. I know little to nothing about this stuff.
