full_mosey
Apr 20, 2020Explorer
DarkSkySeeker wrote:
Thank you for this help. In my mind, I thought only the battery side of the controller was modulated. Now I understand the charge controller allows current flow from the panel in the same way.
Amps are DRAWN by the consuming device. That is why your 1 Amp incandescent bulb does not explode when connected the same battery that can send 200A to the starter motor. You explode the bulb by applying too much Voltage.
HTH;
John
