DarkSkySeeker's avatar
Apr 19, 2020
Solar Charging and Amp Hours
Is the amperage from a solar panel constant as the battery it is charging charges up?
I.e., as your battery reaches full charge, the current drops to zero either via the charge controller or the equalization of the panel and battery, right?
So this simple math is false? 120 watt panel, 12 volt system, 10 amps, 10 hours to charge a 100 Amp Hour battery?
  • There are still experienced RVers with dumb controllers?
  • jdc1's avatar
    jdc1
    Explorer II
    It really depends on your charge controller. Some are "smart chargers", slowing the charge rate as the battery nears the full stage.
  • A 120w panel does not output 10amps
    Out put it more like 7 amps
    Full Working voltage of a 12v panel is around 17v,
    Output from the controller is 14.x to properly charge the battery
    12v won't charge a battery, a battery at 12v is only 50% charged/capacity
  • Yes, false. Charging to 80-85% goes quickly with the battery accepting everything or almost all sent to it. During the absorption phase the battery accepts less and less.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
