westend wrote:
But who says that is the same amps amount as what the Imp is when you divide the array output watts by the controller's Vmp?
You're trying to tie together two measurements?
The current produced by the panel array will be, at best, slightly more than the controller output because of the controller's less than total efficiency...and... by the amount of draw being dictated by the battery. In the case of shading, the current output of the panel array will be less and therefore, the controller's output would be less.
Does that explain a discrepancy?
I have no idea what the two of you are discussing but perhaps I missed something.
Let's go back to basics: Serial matched panels with bypass diodes and MPPT. The current output from the panels is dependent upon the amount of sun and can vary from 0 to the panels Imp. Shadows that activate bypass diodes reduce the voltage and don't effect the current from the panels.
So with the same current and reduced voltage the controller seeks a new maximum power point - that is maximum watts for those conditions. Do not confuse this with the panels rated Imp.
It then converts this input power to the output power by reducing the voltage and increasing the amps. I've observed 49A from my Imp rated panels of 8.2A. Yes the wiring and controller losses are a small factor. The battery acceptance for charging is a big factor on the actual controller output.
Simple example: My array is producing 5A at 90V and 5*90/14=32A which the battery is accepting. A shadow actives 2 bypass diodes of the 9 and now the controller finds a new maximum power point at 5A and 90*7/9V and the output is now 5*90*7/9/14=25A to the 14V battery.
