- Colo_NativeExplorer
This is what I made up still need to paint it. - Colo_NativeExplorer
Calkidd wrote:
I took what I originally posted here and did a little modification. Instead of an electrical box I used a junction box and drilled my own holes to best suit my needs.
That is what I ended up doing as well the only thing I did was add a piece of plastic between the bus bars just in case they broke loose. I plan on painting it to help with the sun issues. If I could figure out how to post pics I will. - OrcadrvrExplorer
Nice Job! - grizzzmanExplorer
Calkidd wrote:
I don't see a reason for a fuse at the box. Unless there is something I am not aware of. I have a 50 amp circuit breaker between the panels and the controller.
The 50 amp breaker will do nothing for a panel failure or a wire short for that matter. Do you REALLY believe a 30 amp source would EVER trip a 50 amp breaker? I agree that you need a switch there and it will serve OK for that. Electricity will ALWAYS take the path of least resistance. If a panel short's out ALL of the 28 amps will go to that panel. Even if it doesn't start a fire, melted EVA could cost you a new membrane roof. I would also rather have 3/4 of a array then NO array while camping. But other then that I see no reason to fuse there. :R - CalkiddExplorerI don't see a reason for a fuse at the box. Unless there is something I am not aware of. I have a 50 amp circuit breaker between the panels and the controller.
- grizzzmanExplorer
Nice work. I have that box and buss bar out in the garage. Have you decided not to fuse at the box? - CalkiddExplorerI took what I originally posted here and did a little modification. Instead of an electrical box I used a junction box and drilled my own holes to best suit my needs.
- pigman1Explorer
Calkidd wrote:
Excessively long run to the charger and battery bank and I was looking to keep line losses to the absolute minimum. Perhaps a bit of overkill, but the additional cost was well within my budget. Don't use the overall current capacity of the wires, calculate the actual percent line losses based on distance and max current carried. I was shooting for approximately 2% line loss. A good line loss calculator
2ga? Seems excessive. Are you running 200+ amps from your panels? - Colo_NativeExplorerI found a place online to buy sunlight resistant wire
http://www.wireandcabletogo.com/XLP-USE-2-RHH-RHW-2/ - rocmocExplorer
Colo Native wrote:
Should I run 10 awg wire from the box down to the controller or bigger can't find uv protected wire in larger sizes
I used #4 as recommended by HandyBob's Solar site, https://handybobsolar.wordpress.com/rv-solar-quick-answer/ and ran the wire enclosed in Conduit. Easy purchase at any local electrical supply.
What is critical is the length of the wire from the junction box to the controller. Longer the run heavier the wire. All explained on Bob's site.
rocmoc n AZ/Fld/Baja
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
