pigman1
Apr 27, 2016Explorer
Calkidd wrote:Pretty much what I did. I did use pre-made electrical ground bars I got from Lowes. I glued a PVC divider between the hot side and the ground side, used waterproof cable connectors where the panel wires come in and my heavy weight down wires to my controller leave from the bottom of the box with a conduit connector and a conduit going all the way down to the RV basement. I also bring each pair of panel wires (six 140W panels) into the box individually and connect them to the bus bars with a mini fuse in the + side. This allows me to connect or drop off individual panels without having loose hot wire ends touching things they shouldn't. Also makes troubleshooting individual panel output easy.
Thus is what I am going to do.
Combiner box
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
