Searching_Ut
Apr 27, 2016Explorer
I've just started building mine. Found a 5X7 weatherproof box on-line that didn't already have holes in it. I glued an automotive type fuse block inside that holds up to 6 fuses. For the grounds I'm just using a ground strip picked up at the local hardware store. All the wiring will be brought into the box with waterproof strain reliefs that I also picked up on line. 10g wire coming in from each panel, 6g dropping down to the controller, 5 panels hooked in series. The fuse box is pretty small so I debated using a 4X4 box but it would have been pretty tough to run all the strain reliefs into it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
