Calkidd
Apr 29, 2016Explorer
TechWriter wrote:I will have to agree the corrugated sleeve with harden and crack probably in one year time. I am not sure about the Eternabond tape. Once you put it down it's there for good. Heaven forbid you have to remove the solar or modify the wiring. You'll be stuck then. They make UV protected nylon cable clamps you can use.pigman1 wrote:
I've also covered it with common black split loom available at ACE or any electrical supplier or auto supply store.
I don't think that ACE stuff will last long.
I covered my solar wire with Eternabond tape.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
