TechWriter
Apr 29, 2016Explorer
Calkidd wrote:
I will have to agree the corrugated sleeve with harden and crack probably in one year time. I am not sure about the Eternabond tape. Once you put it down it's there for good. Heaven forbid you have to remove the solar or modify the wiring. You'll be stuck then. They make UV protected nylon cable clamps you can use.
Eternabond tape can be removed with a heat gun. Sticky, but not difficult.
To get at wires, just use a box cutter to splice the Eternabond tape. Just be careful.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
