johnm1 wrote:
I've been pondering the Bogart 2030 (?) units for the PWM charge controller and battery monitor
This one is truly programmable. Note that you have to buy both units by Bogart. There are monitors that are either better or lower priced, but Bogart controller won't do you any good with a different monitor.
johnm1 wrote:
Just so much info out there and lots of people disagree on what's best for this or that.
Because you need to specify the goals and environment. Too many variables, different goals and different methods.
One limitation of Bogart PWM is that it is PWM. If you ever decide to go big, it will limit your array to ~400W @12V bank, and parallel wiring only.
