red31
Aug 03, 2013Explorer
I can wait on my cheap ($8) controller, esp with features like theses ;)
3. Scientific management of battery:as it is overcharged,the battery will get booster tension charge.As a result compulsory maintenancevis available for the battery.In normal working state,the direct charge and floating charge are both available,so that the battery life-span is increased.Bsides,the adoption of high precision temperature compensation makes the charing more accurate.
4. Comparing with the charing loops using diodes, the one that adopts double MOS series circuit control makes the voltage loss dropped by 50%.With the PWMfuzzy control in charge efficiency is improved a lot
