mena661 wrote:
... if I wanted to tent camp, I would've never started RVing in the first place. Makes no sense to spend 10s of 1000's on a RV just to turn everything in it off.
Like I said, they don't want to hear.
Getting an RV is exactly what many people do when they grow older and are getting tired of tent camping. And not necessarily "10s". Many trailers, and mine is no exception, are under 19K new - but this is again something useless to talk about, when the main argument is "the bigger and the louder - the better". In the same line of thinking is saying that cooking on gas stove, running a fridge less than 20 cu.ft, or watching a TV that is less than 48 inches and is on less than 8 hours a day, is a "tent camping".
mena661 wrote:
There are ways to reduce power consumption though. LEDs, low draw devices, not using SOME things, etc.
Really? :) But this would be a "tent camping", no?
Leaving aside air conditioner, of all the standard RV equipment the only "thing" that should better not be used if the goal is to minimize the generator time - what the poster asked about - is microwave. It requires bigger battery bank and significantly increases daily Ah draw and thus dependency on generator. If you bring more 120V "things" from home out into the wild because you can't feel comfortable without them - it's tough then.
With MW the minimum solar size that would allow not to run a generator on most days, goes from 160-200w to 300-350. Which 350W I do have (and more), so MW is something that I can run with my particular system. Doesn't mean that I have to run it, or run it often, because same tasks can be done on propane if you know how to do it. But you need to know how.
Edit - PS: one more thing.
When batteries need 40 Ah in the morning to make them full, this doesn't mean that I only use (and solar only collects) 40 Ah in 24 hours. It's probably more like 60-70 Ah, but I don't know and don't care how much more. Like BFL said - here I agree with him - solar is "all or nothing" deal. In a daytime when my batteries are nearing 100%, panels generate more current than batteries can take. So any loads that I run after 10.30-11.00 am, are "free" - batteries are sitting peacefully on Float - while I run vents, pumps, charging vacuum, laptop, power tools - yes, I have tools in my 26ft "tent" :) - etc.
So don't get upset, you'll figure it out when you start using solar.
