red31
Apr 27, 2017Explorer
the controller gets it power from the battery so it is connected to the battery.
http://www.naturepowerproducts.com/doc_db/60028_28amp_charge_controller_manual_eng_fre.pdf
Charging Status: (LED = RED)
ON: bulk charge
Flickering: float charging
OFF: battery is fully charged/no charge from solar panel
LCD Display: Shows the battery voltage, charging current
and loads’ current in 5 second internals, during operation
I'd measure at the connecting terminals, solar & battery and compare to battery post measurement. All battery connection should be clean.
I'd also change the Full Charge Cut (Default) 13.7V to much higher, take that back I'd replace this controller with a grape bluetooth and monitor via cell phone app from grape. or any other controller that has charging set pt of 14.6v
ON: bulk charge
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
