Ed_Gee
Feb 28, 2016Explorer II
red31 wrote:All I could afford wrote:
In full sun, with my multimeter on the terminals coming from the pannels I am showing about 18 volts, as expected. However, I am showing the exact same voltage on the terminals going to the battery compartment.
Is this attached to a battery?
attach to a battery and remeasure and re-post results.
New, those panels should measure 21v not connected to a battery, relatively cool, 25C.
connected to a battery while charging, you should measure batt V.
Red31 raises a good point. In all probability that controller needs to be attached to a battery before you can assess whether or not it is working. However, his comment that open circuit panels should show 21VDC is questionable ... that depends quite a bit on the design of the panel ... my new monocrystaline panels show 18VDC open circuit, as yours do so in all probability your panels are OK.
