BFL13
Jun 07, 2013Explorer II
PT can keep his watts; my batteries only take amps. :)
I vote for Mr Wiz to adopt RJ's tilting twirler at each end of his MH since Mr Wiz is out of roof-space and needs more daily AH haul. No need for roof-tilting and parking a certain way (mostly) It all folds up for travelling.
Mr Wiz's 25a controller is already clipping the amps at times AFAIK, so he can divide off a couple of panels and use the second controller at the same time. Now the 25a is not clipping any, and the total amps is higher. Plus you get longer higher amps with the contraptions same as RJ gets.
IIRC, Mr Wiz wants to swap out a couple of the roof panels which are underperforming (can't remember details on that) So could take those off and replace with better panels and use those old ones for the RJ contraptions.
Or something like that :)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
