msiminoff
Jun 07, 2013Explorer II
Um, I don't think I "get the rant" either... Then again, I'm maybe not a typical RV camper.
As Jim (HiTech) said, it's the programability and installation flexibility, that I want the most, MPPT is a secondary benefit. My two SunSaver MPPT15 controllers give me a lot of control over how I care for my batteries and allow me the freedom to use the available power as I see fit. I depend on my solar/battery/inverter setup to run some sizable loads in my TC, including the microwave, air-conditioner and hot water heater... and I almost never run a generator and I don't refill the LPG tank very often.
My "fancy" MPPT controller(s) has a programable diversion load output so when the batteries are full the "extra" power available is used to heat the hot water tank... It has two separate fine-tuned charge profiles (float & daily 3-step) which can be selected with the flip of a switch, it is temperature compensated and has a battery-mounted thermocouple which means that I charge at the correct voltage regardless of battery temp. The control also has a handy serial interface for programming, monitoring, and data logging.
With regard to the MPPT functionality; My panels are wired in series (2x100W and 2x64W) and the strings are each around 37V this means that I'm above charging voltage (~13.6V) from sunrise to sunset (nice if I want to run the A/C on a hot afternoon).
Yes MPPT controllers are more expensive, but IMHO they're worth every penny.
Cheers
-Mark
Cheers
-Mark
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
