RespondingBack
Jun 07, 2013Explorer
Morningstar recently released/published a white paper on MPPT. Their conclusion was that MPPT was best if had a minimum of 200 watts of solar panels. Otherwise, MPPT would not be effective.
As an aside, if using RV constantly, solar controllers which want to go into float don't make much sense as there will probably be a load on the batteries. If RV is in storage, then float makes sense not to kill the batteries.
Also, each battery manufacturer has different specs on voltage for each stage (e.g., Concorde/Lifeline AGMs have different ideal charging voltages than Odyssey AGMs. Programmable controllers allow you to set different voltages and different times (with caveat, that simultaneous loads/drains on batteries may change what stage you are in charging.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
