12thgenusa
Jun 08, 2013Explorer
Salvo wrote:
20% of battery charging time could be in boost mode, while 80% is in absorption. That means you're only using the mppt feature for only 20% of the daily charging cycle. If you're in boost for 3 hours with mppt, then you're only 3.15 hours @ 5% gain or 3.3 hours @ 10% gain when using pwm. The rest of the time both systems charge at the same rate. MPPT is getting plenty of hype.
Sal
This statement may be in reference to your experiment, but if it meant to be a general truth it certainly is not my experience. Of the more than 12 hours my system is charging these days, at least eight are in MPPT. There again it may be different for 24-volt panels.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
