12thgenusa
Jun 08, 2013Explorer
Salvo wrote:
In that case, you must really be solar undersized. Most people state they are in absorption by noon or 1pm. Seems like your batteries never get fully charged; at least not with solar.
Not at all. 370 watts of solar, 440 Ah storage. The last trip out of 13 days, 100% solar, no HU, full charge everyday.
Here's what PD says:
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
http://www.progressivedyn.com/prod_details/charge_wizard.html
PD says the battery is 3 hours in boost when it is starting with 0% SOC. From 0% SOC, boost duration is 27%. We usually start with 50% SOC. Therefore I think 20% in boost is fairly accurate.
What does converter charging have to do with this? Yes, I can charge my bank to 90% in three hours with the WFCO at 65 amps, but that's a different game from solar charging. I will quite normally see 20 to 27 amps from the Rogue with peak watts exceeding rated panel output happening often enough not to be a rare event. Maybe what's confusing you is that I use solar for more than just battery charging. Even after the batteries are in float, usage demand (an afternoon pot of coffee or a movie) will drop the controller back into MPPT to supply the demand.
There's no difference between 12V and 24V panels in this regard.12thgenusa wrote:
Of the more than 12 hours my system is charging these days, at least eight are in MPPT. There again it may be different for 24-volt panels.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
