msiminoff
Jun 10, 2013Explorer II
Mark, the mppt manufacturers got you well trained. Your calculation has several errors. The pwm scenario does not use Imp (5.70A), but rather a current that's very close to Isc (6.10A). That means the pwm power output isn't your calculated 77.52W, but 82.0W.
YES, I agree Sal! My numbers and math are intended to be a "simple description" of P=IxV and I stated that the numbers assume perfect conditions/cold panels/no efficiency losses, etc. The point is to illustrate how MPPT can make more power available than PWM under certain conditions... which is the BFL13 had asked; The hours are the same and the amps the same, so how can you have more AH??
Hmmm 7%... that sounds pretty good to me!
:C
-Mark
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
